1 - 5 of 5 Posts
Hi all you car tec people
Had this problem with the roc this week..
ABS +TRAC/CONTROL lights came on, sent roc back to vw and it needs a new ABS sender unit off side rear no probs booked in next week for repair.
Next morning find a flat… and yes you guessed it off side rear with 6in nail in the side wall are the two connected!!!
could well be - do you have flat tyre monitoring as well ? I'm on a learning curve on this, but when the tyres are the right pressure you press the flat tyre button and that calibrates it - but the ABS software needs something doing to tell it it has flat tyre monitoring as well.
HI
Flat tyre monitoring was not ordered. But had the same problem with the bm run flat system. lights come on , then check all tyre pressures all ok but light still on , back to bmw to find the inside tyre wall had delaminated inside the tyre, and the only reason they new what it was because they had the same problem the week before with a customer car on test had a blow out!!
1 - 5 of 5 Posts
