The VW / Audi specialist B&B from Siegen Germany integrated the VW Eos in their established turbo program.
The result is a breathtaking sports cabriolet which reaches in four different power levels (360, 400, 450 and 500 hp) performance values which are normally reserved for top-class sport cars. The highest increment is achieved by the installation of a new developed intercooled turbocharger, a changed cylinder head with a trimmed compression, special suction and airflow pipes, high powered injection elements and a more precise fuel pump. In order to take the engine stable and suitable for daily use, the ledges, gaskets and several expendable parts are transposed by enhanced parts. By using a special slim line oilcooler the oil temperature will be set on a more stable level. To drain off emissions faster and dull sounding a racing exhaust system will be mounted when finally the optimized engine electronics take place to the tuned parts.
The performance values of the 500 hp / 650 Nm version: 0 to 100 km/h in 4.2 seconds, 0 to 200 km/h in 13.5 seconds, Vmax 308 km/h.
To fulfill the risen requirements a special six or eight bulb high end braking system as well as a threaded chassis, adjustable in height and traction, has to be mounted. This conveys a comfort feeling of security and a confident driving behaviour to the VW Eos driver in every time.
Exclusive tires in 18" and 19" as well as a Eos exclusive aerodynamic program in original manufacturer quality finishes the appearance of the unique sport cabriolet.
B&B Scirocco details here: viewtopic.php?f=5&t=617
