"Darling, this gravy is completely immiscible with the rest of my dinner. I am afraid unless you have an adequate explanation I am going to have to go for a 2 hour drive in the scirocco to consider my druthers at this time."Le_Savage said:Not an expert but are you sure it needs topping up? The MFD normally tells you of such mundane events, and seeing that you have 3 yrs free servicing I would take it along to dealer and get them to sort it. But to answer your question I would be wary of wacking any cheap coolant in as it might be immiscible with what is already in there... hmm that's a good word [note to self, try to include that in a sentence next time I am trying to baffle/impress the wife]
Speaking of Dullards!!sciroccorocket said:you should have at least 40% minimum coolant additive, to top up the spec is G12 plus-plus (TL-VW774 G) or G12 plus (TL-VW774 F) you can top up with either, both are purple in colour dont put any other colour additive in, i would go 50 50 mix water to coolant additive, rember to park on a level surface when checking the level, hope this helps![]()
i have my momentsLe_Savage said:Speaking of Dullards!!sciroccorocket said:you should have at least 40% minimum coolant additive, to top up the spec is G12 plus-plus (TL-VW774 G) or G12 plus (TL-VW774 F) you can top up with either, both are purple in colour dont put any other colour additive in, i would go 50 50 mix water to coolant additive, rember to park on a level surface when checking the level, hope this helps![]()
But in all seriousness you actually sound like you know what you are talking about![]()
