G
Guest
·Not sure if this is normal but when I fold the drivers seat forward it doesnt return to the same position. You have to slide it forward again using the handle under the seat.
Is this normal?
Is this normal?
Hmm thats what I thought. Once i fold the seat up and sit back in it i then have to slide it forward again. Annoying!scottyroc said:no, once mine is folded forwards, i make sure to slide it all the back to its original spot, then fold the seat up and it goes back to its previous position, very strange :shock:
again......scottyroc said:doh....back to the stealers for you my son... :thumbdown:
I always thought it was designed to work like that for safety and ease, for example you have the seat all the way back - you let someone in, then they've sat in and you push the seat back only to smack their legs, at least this way it forces a stop.imitebeurda said:Yeh rehmondo, mines the same as yours.![]()
PAJPAJ said:kianok
Your seats should return to their original position as is stated in the manual.
I have just tested mine in various different positions and each time they return to their initial position except when they are fully back in which case they stop a little short of that position (as stated by rehmondofor safety reasons).
I have noticed that the seat back has to be fully pushed down after you pull the catch. If it's not pushed hard down they don't return and instead stop in the forward position. I presume either the catch or the back rest going down "mark" the position. Also you have to keep the seat back in the tilted position whilst you slide it back or the seat will just stop in the forward position you have just pushed it to. I thought mine was not working properly when I first got the car but I think the mechanism just need freeing a few times - particulary the back rest going fully forward/down when the catch is pulled.
Peter.
