1 - 1 of 1 Posts
I hope you all remembered to change your clocks last night!
Please note the following: The forum time has adjusted and is correct. If however when you log-in the time displayed is incorrect, see below.
You can either leave it as is, and it will be correct six months of the year (and WILL NOT effect any of your postings) or you can amend it. To amend this you need to go to your 'User Control Panel' (top right), select the 'Board Preferences' tab and then select 'YES' under 'Summer Time/DST is in effect'. While your there remember you can update your profile, avatar and signature.
Tony
1 - 1 of 1 Posts
