Hi, quick question. I know to fit the foot rest pedal you have to remove it, drill it, fit pedal and refit to car.
I can see there are 2 plastic bolts/grommits that you remove and then the foot rest and plastic "sheath" behind the pedals should come off. The first one behind the brake/clutch came away easily enough, there is a "groove" across it, a quick turn of a flat headed screwdriver and that was that. The second one is on the side of the foot rest. It appears to have a little hole in the top of it. I have tried to remove it but to no avail. I didnt want to force it without knowing, I know a few of you guys have fitted this footrest. Can you tell me how the second bolt/grommit come off?? Ta!!
