1 - 20 of 22 Posts
A product that has recently come to promenance in the world of detailing is Detailing Clay. In this thread I aim to write a general guide to what clay is, what its used for and some generic tips for how to get results from clay. I will focus on the use of clay for the removal of bonded contaminants.
What Is Detailing Clay??
While clay is growing in popularity with many detailers now, it has certainly not become a well known "household" car detailing product. Detailing clay is a substance that is designed to remove bonded contaminatns from paint, leaving the paint smooth as glass, allowing easier and more fruitful applications of polihses, glazes, sealents and waxes. Detailing Clay is wiped gently across the paint which needs to be lubricated with a lubricant such as a Quick Detailer spray.
Clay, like polishes, comes in levels of aggressiveness - if you are a beginner with clay, do start with a mild clay such as Meguiars Quik Clay, Meguiars Professional Mirror Glaze Clay (mild, the blue bar) or Sonus Green Clay. These mild clays should be enough to remove bonded contaminants from most cars, only step up to a more aggressive clay if absolutely needed.
Clay can be used on paintwork, glass, and wheels. Always use separate clay on each - ie dont first clay your wheels then use the same clay to clay your paint, as all the brake dust embedded in the clay from the wheels will scratch the paint.
What Are Bonded Contaminants??
When you come to wash your car, the paint will be covered in lots of fresh contiaminats such as dust, mud, possibly bird boms and many others. In addition, the paint will also have a growing amount of bonded contaminants attached to it, which accumulate over time:
When you wash your car, the fresh contaminants are removed from the paint and the paintwork looks clean. However, washing will leave behine the bonded contaminats which are attached to the paint as if they had been glued on:
These bonded contaminats are hard to see, so after washing your paintwork looks clean. However, if you gently run your fingers acorss the paintwork you may feel that the paintwork feels rough - a bit like stubble in a way. This roughness, grittiness that you are feeling is the bonded contaminants in the paint.
Examples of bonded contaminants are:
> Brake dust - sharp, so embeds itself in the paint
> Industrial fallout
> Tree sap - very sticky so adheres strongly to the paint
and there are many others as well which you're car is subjected to on a regular basis.
Removing Bonded Contaminants - Clay
In order to remove the bonded contaminats and restore a glassy smooth feel to the paint, detailing clay is used. As well as leaving a pleasingly smooth feel to the paint, when you come to polish, glaze, seal or wax, it means that you are now sealing in remaining bonded contaminants if you have removed them by clay. Simply washing and waxing will not remove bonded contaminants, they will be left behind and then just waxed over.
Clay basically works by grabbing hold of the bonded contaminants and pulling them off of the paint surface:
The contmainats become stuck in the softer clay where they remain. A safety note when using clay here - these bonded contaminats are stuck into the clay and the clay represents a flat surface. Therefore, surface marring can occur if not enough lubricant is used, or the clay is not kneaded regularly enough to a clean side - please see also the section on using clay...
This leaves the paint finish glassy smooth. Clay can remove the bonded contaminants listed above, however some adhesive contaminants such as tar may need a dedicated tar remover as they are very highly adhesive.
Using Clay
Before claying, always wash fresh contaminants off of the car. First and foremost, always follow the manufacturers instruction for the correct use of their detailing clay. What follows here is a generic guide of tips for the safe use of clay which I use from experience of using clay.
To clay your car, you will need a clay bar and an associated lubricant to lubricate the surface and the clay bar - examples of such lubricants are:
> Meguiars Quick Detailer Spray
> Meguiars Last Touch Detailing Spray
> Meguiars #34 Final Inspection
> Clearkote Clay Lubricant
> Pinnacle Poly Clay Lubricant
and there are others that can be used too.
About 40 - 50g of clay is sufficient to clay a moderately sized car. If using Meguiars Quick clay, for example, break off one third to one half of the clay bar (the bigger the car, the more clay you may need).
Roll the clay up into a ball, then out into a sausage shape and finally flatten it out into the palm of your hand. When doing this ensure that the clay is warm and quite soft. It clay gets cold, it can be hard or brittle and this can risk inducing surface marring on the paint. Throughout the claying process, always ensure that the clay remains nice and warm and doesn't go brittle or hard.
Work on small areas at a time, I start with the roof, and then the bonnet, then the top half of the sides, then the boot, then the bottom half of the sides (like washing, do the cleaner areas first). I always spray a panel with quick detailer and wipe off before claying it to remove and rogue dust particles that may have blown onto the paint that may induce marring.
Work on small areas of paintwork at a time - about 2' by 2'. Spray the area with the clay lubricant, enough to wet the surface quite thoroughly. Also spray the clay with lubricant as well. Gently wipe the clay in a fore and aft motion over the lubricated area using only finger light pressure:
Never clay over a dry area of paint, and if the paint begins to dry out before you are happy that the surface contaminants have been removed (paint will feel smooth), spray on more lubricant. Keep the clay lubricated as well. Once the paintwork feels smooth, gently wipe the remaining clay lubricant away using a soft microfibre towel.
Knead the clay very regularly - this not only keeps the clay warm, but when kneading expose a clean side of the clay. Remember that clay is picking up sharp particles, if you do the whole car with one side of clay you will induce surface marring as all the sharp particles stuck in the clay will ineveitably come into contact with the paint. For this reason, knead the clay regularly and only ever use finger light pressure. When a clean side of clay can no longer be revealed, discard the clay.
Continue until the car is completed. Note that many clays will remove some or all (depending on aggressiveness) of the wax/sealent protection, so always follow up claying with polishing and glazing if required, followed by sealing and/or waxing.
Some Notes on Safe Clay Use
Clay is safe to use if used with care. However, if not used with care it can induce surface marring.
Always regularly knead the clay to a clean side.
Always keep both the clay and the paint surface well lubricated.
Use only finger light pressure
If you drop the clay on the ground, discard it as it will pick up tons of dust and grit and dirt from the ground that will inflict damage to paint.
Keep clay warm, and supple - if it gets cold, hard and brittle it will induce marring, so another reason to keep kneading regularly, especially in winter.
And there we have it, a quick generic starters' guide to clay.
REMEMBER even a clean car benefits from claying, as a rough guide, wash-dry-clay-wash-dry-polish-glaze-wax. This should be done twice a year to ensure a high quality paint finish is maintained.
One question... Use clay after dry car or use clay when car still wet????
A bit confuse to me because some said use it still wet don't use when car dry...
If your going to clay your car make sure it is freshly washed, no need to dry as you will be using a lubricant (people use various things from a quick detailing spray to a very mild soap solution - experiment and see what works best for you)
J.
Discussion Starter · #10 ·
Before claying, wash your car, you need to get rid of the surface particles otherwise "claying" can actually cause damage to your paintwork as you are rubbing the surface dirt into the paint.
Once washed, and dried then either use detailing spray (you get a bottle with the meguairs clay bar in the kit) or wet the car to use the clay, IMO detailing spray gives better results. Only do one panel at a time, working the clay slowly over the area (remember to "knead" the clay first to make it pliable) once the clay has become dirty, ie the particles it has picked up, fold it over on itself so you are always using a clean part of it.
Once you have finished claying wash the car again to avoid the "smear" look, dry the car and the polish/wax to seal the paintwork.
Thats the way I was taught :thumbup:
Might want to mention too as this seems to be a regular question I get asked when people are new to claying....ensure you apply polish and then your last stage product (lsp) or just the lsp afterwards :thumbup:
We offer a clay kit for £9.99 which includes 1 x bar of fine yellow poly clay, 1 x Juicy Lube, 1 x EuroW All Purpose Microfibre
http://www.juicydetailing.co.uk/det...ng-beginners-clay-kit/flypage_images.tpl.html
how does claying compare to compounding ?
i intend to give our volvo a really good seeing to before I put it up for sale,
i was planning on compounding with something, maybe that Farecela stuff, and then waxing it..
its a metallic, and it in really good condition.
(i have actually good a machine polisher btw, I use it on my dancefloor but thats another story :lol: , its a silverline rotary one)
I've started using Bilthamber clay (http://www.bilthamber.com) - seems to do the job although I haven't used any other type to compare it with to be honest. Lubes with water too - always a bonus I find :thumbup:
Have suggested it to http://www.juicydetailing.co.uk, the new car care sponsor, as a possible stock item.
Claying and compounding are two very different things. The clay removes any contaminents from the paintwork making it ultra smooth and an excellent base to apply further products such as a wax. The wax is not only a protection but it is also a lens through which you see your paintwork (which is why preparation is the key), so thus will affect the end look.
'Compounding' or polishing is where you are using a variety of liquids that contain various elements of abbrasiveness to remove paint damage such as swirls and scratches. Ideally you should clay the car before polishing as this will show the true condition of the paintwork plus by removing any contaminents which can be caught in the polishing pad and incurring additional damage to the car.
As mentioned depending on the existing paintwork condition I would certainly clay the car as this will not doubt improve the end look and if 'you' feel its necessary to polish the car with the silverline then its your personal choice. It depends on whom your aiming your sale at as the majority of people are not as anal about swirls as some of us :whistle: naming no names!
I would also say that if your looking to spend the time polishing it then is it worth the effort with the price your charging for the Volvo? Maybe just consider an enhancement rather than a full correction
I have a question, mainly aimed at madame jen but if anyone else can help be cracking!
I bought my car from VW in september and the pre pick up wash scratched my paintwork, now without getting into a rage about it I have finally got the VW dealer in Leicester to agree to have the problems fixed, they had already had a go at cutting it etc but did a shocking job so I refused to let them even talk to me.
Now its going back into another VW garage very shortly for a full machine polish and was wondering if I could aid them in doing a slightly better job by giving it a good clay myself before hand. Or will it make no odds if there using a machine polisher??
note that the product maguire is not tested in the current clear used by the manufacturer, products 3m yes however there is a very good product liquimoly and tested without problems.
1 - 20 of 22 Posts
