1 - 20 of 31 Posts
Hello all! All the way Johannesburg, South Africa:
Year: 2011 (2012 Spec)
Car: Volkswagen
Make: Mk3 Scirocco
Model: GT 2.0 TSI
Specs: Rising Blue / DSG / Xenons / Panoramic Sunroof / PDC
Mods: REVO Stage 2 / APR Carbonio Intake / Flowtech 76mm DP / NGK Iridium Plugs / JOM Coilovers / RNS 510 / 9WZ Premium Bluetooth / HID Fogs / LED Interior and Parklights / Lamin-X & VPS / Vag-Com Tweaks /
Discussion Starter · #2 ·
All interior bulbs and park lights replaced with LED's:
Soon to be replaced by PerformanceLED's.
Performance wise I have a 76mm Flowtech DP, APR Carbonio Intake, NGK Iriduim plugs and REVO Stage 2 software.
Discussion Starter · #4 ·
Fitted a RNS510 & 9WZ Premium Bluetooth:
Discussion Starter · #5 ·
Finally, JOM Coilovers :)
Before: (Note the yellow calipers..after a month I could not keep them clean anymore)
Blue calipers in the making:
After: This was just after fitment..she is sitting even lower now :)
Next up is 5mm spacers all round!
Discussion Starter · #6 ·
Had a track day this past Sunday...here is a few pics:
Discussion Starter · #7 ·
So it snowed here in Joburg, South Africa for the 1st time ever and I took the opportunity to take pictures with my iPhone:
Discussion Starter · #8 ·
Found myself some wheels :D
3SDM 0.01: 19" 9.5j ET40 with 235/35/19
There is currently 2 companies from the USA that can get them to SA..dealing through 3SDM in the UK themselves has turned out to be quite slow.
I'll hopefully have them next month..and I think I'll have to get H&R Ultralows to compliment them as the JOM's do not go low enough at the rear.
Awesome build and pictures fella :thumbup: :clap:
I was thinking you would need to get spacers but since you have new rims it doesn`t look like you`ll need that :think:
Snow? Thats crazy sh!t. :crazy:
Keep up the mods....now a dyno run?
Discussion Starter · #12 ·
Thanks Gents!
Yes, 5mm spacers are lying in the garage but with a 9.5J wheel and a 40 offset they will not be needed :D
The VW Club of South Africa is hosting a dyno day this Sunday so a power run will be made...I'll need to raise her (I call her Mila :oops: ) to get onto the dyno :mrgreen:
Discussion Starter · #14 ·
Hey Zaeem...£760 before shipping & customs..
Discussion Starter · #16 ·
Thanks mate! Replied.
  • Like
Reactions: Richiehill1988
Discussion Starter · #17 ·
Picking them up today from the local distributors Imcomex and fitting them after work :grin:
BILSTEIN B14
Sport makes you flexible.
With the BILSTEIN B14 threaded ride height adjustable kit, we're bringing technology from the race track onto the street.
The product benefits at a glance:
•Threaded body adjustable range of 20 mm at both axles, while installed
•Lowering of approx. 30-50 mm at front and rear
•Road-tested by BILSTEIN under motor sports conditions and fine-tuned
•Spring plates and lock nuts made from a special aluminium alloy
•Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
•Round threads for ease of adjustment
•Quality sport springs made from highly durable material
•BILSTEIN gas pressure technology
•BILSTEIN mono-tube/Upside-Down technology, made in Germany
•German TÜV certificate
Discussion Starter · #19 ·
VW Savannah - 19" 9J ET33
1 - 20 of 31 Posts
