Flux said:
The only problem that comes to mind... Is, adding aftermarket mods that help handling like lowering springs, roll bars and braces, conflict with your cars traction. Remember when the car leaves the factory, its ECU and Traction/Stability is in a state of equilibrium. You change one the other loses its self a little bit, I had the same problem with my SLK but its nothing drastic. Just means you have to tinker the traction and its not that dear and its rather easy :thumbup:
Disagree. Doing one does not mean that everything else immediatly becomes worse. Quite often you improve all other areas with simple changes.
Anyway, Fitting Front Strut braces to the Scirocco chassis will require cutting of the scuttle panel to allow the brace to come out into the engine bay, as the turrets are under the scuttle. look at MK5's for examples. A Rear strut brace adds litte to the car due to the nature of the rear suspension design, as its all housed on a subframe, and the springs direct the load at the subframe/floor pan and not the top of the turrets(in spring over damper setups), the bracing effect between the turrets doesnt actually help much.
Uprated ARB's are a superb addition to any car, I've fitted uprated ARB's to a number of cars and generally they are the best value for money mod to improve handling. You'll find they R will likely have an uprated ARB fromt he parts bin. I've nto looked at what some fo the Audi's run, but there will be OEM bars that are thicker for sure. Or aftermarket ones which are stiffer again.
There are a number fo OEM upgardes that i am looking at from various Vw and Audi parts bins that havn't made into onto the Scirocco that will improve it.
