Probably. You will know by the way the car handles, and in time the way the tyre wears. I am no expert on this but I wouldnt have thought you would have a problem at that psi. If the car handles like a pig around the bends you could knock it down a little, and if you start noticing the centre of the tyres wearing worse than the edges you know its over inflated. If you cant find anything in the manual you could always ring VW, or a tyre dealer (kwik-fit etc) and ask them. If you dont get any joy then a bit of trial and error.Sam63 said:So for 18's running them at 36 all round should be ok then?
:lol: :lol:davedavison said:Hi sam,
my 18 interlagos are at 37psi, that is what my local tyre dealer told....no hes not that kind of dealer... :shock:
DO NOT pump your tyres to 50 psi! this is max rated for tyre. For fun go out and blow your cycle tyres to the max number on the sidewall and see the effect and if they are old tyres make sure your standing behind a brick wall!donnie darko said:on the sidewall of the 18" tyres it says 50psi, and the same on my 19" shouldn't you have it at 50 then? when i picked my car up after a few weeks i noticed they were quite flat and when i checked they were at 25psi! i put them up to 40, but don't know what the ideal psi is for fuel efficiency?
I think the PSI quoted on the tyre is the max allowed for that tyre is it not? 40 is way to high. circa 33 is where you want to be.donnie darko said:on the sidewall of the 18" tyres it says 50psi, and the same on my 19" shouldn't you have it at 50 then? when i picked my car up after a few weeks i noticed they were quite flat and when i checked they were at 25psi! i put them up to 40, but don't know what the ideal psi is for fuel efficiency?
beat you by 1 min!Evil Derboy said:I think the PSI quoted on the tyre is the max allowed for that tyre is it not? 40 is way to high. circa 33 is where you want to be.donnie darko said:on the sidewall of the 18" tyres it says 50psi, and the same on my 19" shouldn't you have it at 50 then? when i picked my car up after a few weeks i noticed they were quite flat and when i checked they were at 25psi! i put them up to 40, but don't know what the ideal psi is for fuel efficiency?
Damn you BAIKAR! :lol:BAIKAR said:beat you by 1 min!
